Removing Overscan / Borders
FluffyLob
Hi all,
Just wanted to share the progress that's been made in removing the ugly borders and / or overscan when running linux.
To recap the problem - if your TV overscans a 720p/1080i feed, you have the choice of feeding true 720p and putting up with the overscan, or a reduced resolution (1188x644 or something) by ommiting the "-f" switch on ps3videomode - then you get fugly borders, but at least you can see everything.
Minkey, over on ps3hax.com put forward the idea of changing those values in the framebuffer driver source. I just got around to testing that theory and it seems to work great. If you want to give it a go, you'll need to fetch the source for a ps3-linux kernel and edit the ps3fb.c file before compiling the kernel. The changes to the file are:
Set the margin values for the 720p scaled mode in the static const struct ps3fb_res_table ps3fb_res section to a lower number than default, as so:
{ 1280, 720, 30, 10 , 0},
and also make the corresponding changes in static const struct fb_videomode ps3fb_modedb as so:
/* 720p */
"720p", 60, 1220, 700, 13481, 298, 148, 57, 44, 80, 5,
The first change indicates the number of pixels on each side to remove from the original 1280x720 feed - so in the example above, 30 pixels from each side (left and right), and 10 pixels from each end (top and bottom) - for a total of 60 pixels removed in width and 20 in height. That gives you the figures for the second change (1280-60=1220 and 720-20=700). The best figures for you will depend on the specific screen you're using. Experiment with different numbers.
For info on rebuilding the kernel, I pretty much just followed the guide here:
http://julipedia.blogspot.com/2007/03/building-updated-kernel-for-ps3.html
Although I was building on the PS3 so didn't need to worry about any of the cross-compiling stuff.
So far I've checked that the kernel boots, the command line (non-X) part fills the screen, as does KDE. I haven't checked if there's a performance hit after making the change yet.
Oh, I did this under Gentoo, and had to be running 64bit userland to get the kernel to compile - although it may be possible to compile it in 32bit userland, I couldn't figure it out :)
Now, if only we could have a bit more video performance! :)
Chris
R
RE*AC*TOR
That sounds great. Is there anyway someone could recompile the kernel in this way to be redistributed, so everyone doesn't have to?
Or could you try to draw up a step-by-step guide?
Also could you just do:
{ 1280, 720, 0, 0 , 0}
/* 720p */
"720p", 60, 1280, 720, 13481, 298, 148, 57, 44, 80, 5,
FluffyLob
My kernel building skills aren't the best in the world - I'm still getting some errors on boot up (most likely due to not compiling in support for certain things) so mine isn't really ready for sharing. I'll keep plugging away though.
/* 720p */
You could, but then you'd get the same overscan as if you ran ps3videomode with the -f switch - at least that's what I got. The workaround here centres around choosing the right resolution to fill your specific screen: Too low gives you borders, too high gives overscan.
Chris
