Removing Network name?
Discussion in 'Mobile Phones Forum' started by -Spike-, Jan 1, 2004.
  1. -Spike-
    -Spike-
    May 17, 2001
    1,507
    E.Sussex
    +203
    Hi all,
    Have a Motorola E635 on Orange PAYG.
    What I'd like to know is if it is possible to remove the "Orange" network name that is displayed on the screen all the time?
    Regards
  2. shodan
    shodan
    Dec 11, 2001
    10,125
    shoeburyness
    +4,406
    If you were to get an operator logo from the net or advert from the paper or something (you know, a word or piccie or something) then that would replace the network name you have on your screen.
  3. -Spike-
    -Spike-
    May 17, 2001
    1,507
    E.Sussex
    +203
    Thanks for your reply shodan, much appreciated.
  4. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    I havn't heard of your handset before, perhaps you mean E365? I believe a bit of software called 'DMTools' may permit editing of the operator logo.
  5. -Spike-
    -Spike-
    May 17, 2001
    1,507
    E.Sussex
    +203
    Yep, sorry Lynx that's the one.
    Will give that a try if I can work out how to.
    Cheers for the reply.
