removing macro vison.
Discussion in 'Cables & Switches' started by GalacticaActual, Oct 21, 2005.
  1. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,130
    Galactica C.I.C.
    +356
    Hi all,
    dont know if anyone can help, but a mate of mine wants to transfere some old VHS tapes to DVD. They are prerecorded and have macro vison anti copying signal on them. Its for his own use and not to resell. I dont have a recorder so I dont know if they suffer from macro vison problems. I I dont really know what to suggest to him. However I thought that I may get result here.
    Any help , or point in the right direction would be appretiated.
    Thanks in advance.
    Dave.
  2. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    You can buy a scart lead with built in macrovision removal. I had one a few years ago and cost £23 back then but did the trick.
  3. unique
    unique
    Aug 14, 2005
    9,381
    +1,211
    depending on the dvd recorder, you might not have a problem here. at www.dvdrhelp.com there are hacks that might let you disable macrovision protection or bypass it. i have a liteon 5005 and you can bypass by starting the recording when a non protected source is displaying, keeping the recording on pause so you don't record anything, then swap the source tape and unpause and it records fine as it only checks for protection at the start. unlike vhs - vhs there is no "spoiling effect". with other recorders i think you can disable the protection alltogether.
    also, when transferring my old tapes across, mostly music vhs tapes of concerts etc, i found that most of them didn't have any protection in the first place, but i'm sure it's a different case with movies
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,130
    Galactica C.I.C.
    +356
    Any idear where from?
  5. unique
    unique
    Aug 14, 2005
    9,381
    +1,211
    you used to be able to buy "image stabalisers" a few years ago that stripped out macrovision, but i think a law was passed to prevent the sale of them so the likes of maplins had to stop stocking them. you might need to get one "under the counter" or from outwith uk
  6. celtic1967
    celtic1967
    Oct 17, 2005
    1,132
    Luton
    +38
    I,ve got one. Used it to transfer kids videos to dvd. PM me if you are interested in buying it as I no longer use it.
  7. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    There's one here
  8. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,130
    Galactica C.I.C.
    +356
    NIce link, bit concerned that you cant see a picture of the product though, still I was pass on the info :smashin: :smashin: :smashin:
