ManWithNewName
Hi All
I've found one post on the forum from back in 2007, but the answer wasn't too clear to me, so I'm asking myself...
When stripping the outer insulation from QED Annv. XT you see the silver cable, but beneath the silver cable there is a solid coloured plastic strip - this denotes the phase of the cable.
Can you tell me if it's better to remove this inner plastic bit, along with the outer insulation, or should I leave it where it is?
Hope that makes sense...
S
S
