removing AC3-RF?
canavan
Is there anything non-obvious to consider if I want to remove the AC3-RF module from my AV32R-DP? As far as I can see, there's only one nut to unscrew and 2 plastic standoffs to undo. Does anyone know the 'secret' key codes to disable/enable the module, or will its absence be detected automatically? Is it possible to replace the AC3RF with a conventional coax SP/DIF input (not as a factory option, obviously, but can it be hacked, e.g. by connecting some pins on the mainboard's connector for the RF-board)?
AMCross
i seem to recall you need to move the switches on the dipswitch under the board when you remove the ac3 module
liam_b
there are no 'secret codes' for the AC3 RF module, it's detected by the AV32R on power up, once removed it won't be detected.
canavan
AMCross: I have to admit I haven't seen any dip switches in any of my AV32Rs. Do you happen to have any information what the other switches (if there are any) are good for, and which one is for the AC3-RF? Or is there consensus that it is auto-detected?
AMCross
just behind the LD digital inpt is a two switch dipseitch i seem to recall you needed to put it in one position for the ac3 unit to work as a rf input and the other way for the rca 2 to work as a coaxial digital output
my last two av32R 192 SP had the switch :confused:
canavan
It's not that my AV32Rs don't have them, I just haven't looked for them, and may just have forgotten seeing them. I'll have a go at removing the RF board when I get my hands on a new rectifier. Thanks for the help so far.
