Removed Netflix....now not in the app store.?!
Comfysofa
As above - netflix wanted to update itself and when i set that off came back with an error - something along the lines of "content cannot be displayed" or something lik that - so, i though ill remove and then go and pick it up from the app store, fresh install and all that....but, its not in the app store not even if i search for it...
Anyone else had that?...yes, it is connected to the net on hard cable...
Dodgexander
Just checked your post history.
LG Nano90
Factory reset on the TV, see if Netflix comes back. With software issues:
1. Power off TV, turn off at the plug. Turn back on.
2. If its still the same, try reinstalling/deleting/install the app again.
3. If its still the same, factory reset.
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
