1) Go into the 'Locked Channels' section of the 'Settings' Menu. You will need the PIN for this bit so the kiddies shouldn't be able to do it.
2) Move down to the movie channels and lock the channel and then unlock it again.
3) Do this for each of the required channels.
You should now be able to switch between the movie channels without a PIN as if they were any other channel. This is how the system should work for us adults that don't have kiddies around.
working 100%
working 100%
