Remove smell in receiver?
Discussion in 'AV Receivers & Amplifiers' started by PeterTv, Jul 19, 2018.
  1. PeterTv
    PeterTv
    Sep 25, 2017
    2
    Sweden
    I just bought a Yamaha RX-V3067, the problem is that it has a smell of some kind of incense, not on the chassis but inside on the components.
    I wounder if anyone here have any safe method in removing this smell, I cant stand it.
  2. mushii
    mushii
    Apr 3, 2003
    2,245
    116
    Stoke On Trent
    +1,205
    The best way that I have found to remove odours (have used on electrical equipment to remove cigarette smoke odour) is to place the item inside a large polythene bag, empty 1 - 2 bags of rice in the bottom of the bag (not over the equipment) then seal the bag and place in a warm place (black bag in direct sunlight) for 2 - 3 days. This often will trap the odour in the rice (like a desiccant) as the odour molecules are often bound to moisture. You may need to do this a couple of times and it may not get rid of the odour 100% but it will reduce it very significantly.
    • Like Like x 1
    • Agree Agree x 1
    • List
  3. dante01
    dante01
    Mar 5, 2009
    46,624
    +11,244
    Try placing the receiver in a sealed container along with some charcoal briquettes.
    • Like Like x 1
    • Agree Agree x 1
    • List
  4. stranger
    stranger
    May 29, 2003
    2,610
    5
    137
    Manchester
    +908
  5. dante01
    dante01
    Mar 5, 2009
    46,624
    +11,244
    Put a dead cat on top of the receiver. This will not remove or erradicate the smell of the incense, but the odour of the cat will overpower it. :lesson:
  6. stranger
    stranger
    May 29, 2003
    2,610
    5
    137
    Manchester
    +908
    That would cause the receiver to overheat- but it would slow cook the cat :)
  7. Dolus
    Dolus
    Apr 26, 2005
    600
    46
    Gosport
    +186
    Carefully open the receivers case and remove any vicars who have mistaken it for a church.
  8. dms
    dms
    Apr 14, 2008
    499
    43
    +211
    I've always found my receivers (which have always been Yamaha ;-) stink (of course it's hard to describe smells, we're not talking rotten eggs here I just call it the "new electronics" smell) when first turned on. I've never done anything to get rid of the smell and it goes after they've been powered on for long enough. So if you're worried just leave it running...
    I've noticed the same with other electronic goods too, it's clearly something to do with the manufacturing process. Pretty sure my Panasonic 4k player had the electronic product smell when first turned on...
  9. dante01
    dante01
    Mar 5, 2009
    46,624
    +11,244
    Serves you right for buying AV equipment from a hippy.
    Don't buy AV gear from anyone wearing a caftan or beads!
  10. mushii
    mushii
    Apr 3, 2003
    2,245
    116
    Stoke On Trent
    +1,205
    I think the smell that you are describing is conformal coating, which is a solvent based protective layer often applied over circuit boards and components to provide a layer of protection. The smell is often the residual bits of organic solvent being driven off as the equipment heats up. Over time the smell will disappear as all of the volatiles leave the coating layer.
    We use a lot of Conformal Coating on our electronic manufacturing sites and it is what many people describe as a ‘new electronics’ smell.
  11. dante01
    dante01
    Mar 5, 2009
    46,624
    +11,244
    It is basically the same stuff that David Dickinson is coated in :lesson:
