Remove scratches on screen?
Discussion in 'Plasma TVs' started by Likvid, Jun 25, 2005.
  1. Likvid
    Likvid
    Dec 31, 2004
    489
    +9
    I have some scratches on the plastic screen that covers the panel on my Panny.
    Is there some way to remove this by using the same product you use to remove scratches on CDs?
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,583
    Spaghetti Junction (really)
    +1,921
    :eek:
    Not that I know of.
    Not very helpful, I know, but wanted to pass on my sympathies, because my CRT was repaired by a (normally brilliant) friend and it got scratched, hence me buying a plasma.
  3. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,059
    2
    4
    137
    Garstang, Lancs
    +1,597
    T-Cut???
  4. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    :rolleyes:
    S.
  5. greyhorse
    greyhorse
    Apr 16, 2005
    445
    You can purchase a product from Mazda, that removes fine scratches on the glass of convertibles, I know it works as I had to do my mothers car. It comes in a 2 pack product, it does work and takes out really fine and deep scratches without damaging the plastic glass window.
  6. BliarOut
    BliarOut
    I used to use toothpaste to polish the small scratches out of my visor on the motorbike and it worked very well.... Then again, those visors didn't cost the best part of £2k :D
    Disclaimer:
    Try on an inconspicuous area first ;)
  7. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    Plexus is a very good mild plastic polish
