brodders1979
I am wanting to run the sonos play 1 cable through a built in chest of drawers to a plug socket hidden within. This means drilling a hole in the top to feed the power cable through which I am fine with. The problem is the sonos connector is rather large so means it will require a large hole to get that end through. Normally I would unscrew/unwire the plug and use that end but its a welded plug. Would i be ok to cut the wire and then reattach a standard plug?
