Remove a ripple?
Discussion in 'Projectors, Screens & Video Processors' started by Mat-Moo, Jun 7, 2005.
  1. Mat-Moo
    Mat-Moo
    Jan 7, 2003
    766
    +6
    I have a basic 16:9 pull down screen, set up and on the left hand side there is a 6" ripple/dent. Anyone know a trick/how I can tension this up?
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You could try some gentle heat from a hair drier.
    Your risk, though ! :)
  3. Mat-Moo
    Mat-Moo
    Jan 7, 2003
    766
    +6
    The ripple runs all the way down (sorry forgot to mention), it's like it need pulling at the bottom (outwards) or something.
  4. binbag
    binbag
    Jun 16, 2004
    1,694
    +81
    I improved my DRH manual screen by slipping a thin iron rod (1/8th inch) into the bottom bar. It needs a little help to retract now, but is definately flatter.
  5. jw250
    jw250
    Nov 10, 2004
    148
    London
    +14
    Is it possible that the screen is hanging at an angle? If it isn't mounted perfectly horizontally then the lob-sided weight will give you a 'wavey' ripple on one side.
  6. Mat-Moo
    Mat-Moo
    Jan 7, 2003
    766
    +6
    If I pull off the end cap (left side) I can pull the material (only aq tounch) and it's perfect. It's mounted on the ceiling direct, which I assumed (wrong!) was flat. I think I can probably hack it with a split rod or deomthing, ling binbag to improve it, just too lazy at the moment as I'm watching too many films!
  7. spickee
    spickee
    May 8, 2001
    239
    MK
    +5
    Might find the slat bar is bent slightly so not exerting the same tension across the screen.
  8. Mat-Moo
    Mat-Moo
    Jan 7, 2003
    766
    +6
    Funnily enough it was a tad, but I had already straighten it :)
