remotes
Discussion in 'Home Cinema Control & Remote Controls' started by dpc, Dec 2, 2003.
  1. dpc
    dpc
    I am looking to replace all my remote controls with one easy to use device. My only problem is
    1, money!!! don't really want to spend much more than say £150-175, which could limit me i'm not really sure.
    2, My kids bless em are only 5 & 10 and will use the device if their mum is not supervising when they watch tv or a video or dvd.
    What would anyone recommend I look at for simple robust easy to use controller apart from banning the kids from watching TV.
    the systems it is to be used for are
    pioneer plasma, denon 3803 amp, pioneer dvd player, JVC video, sky digital, subwoofer
    Can anyone help, please??
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  3. The Robman
    The Robman
    I'd suggest that you check out the regular One For All remotes (ie, not the Mosaic which the kids will drop and break).
    Most will already have built in codes to work all your devices, and if you find that you have 1 or 2 devices that lack codes, most OFA remotes also have modems built in so you can download the additional codes you need over the phone or from the web.
    Plus, with the addition of a homemade JP1 cable, these remotes are programmable from your PC.
    All for about £30 or so.
  4. petrolhead
    petrolhead
    Mar 29, 2002
    4,485
    71
    Newcastle
    +82
