Remotes for DV88+ and A85
Discussion in 'Arcam Owners' Forum' started by vanwel, Dec 16, 2003.
Tags:
  1. vanwel
    vanwel
    I've got a questions about these remotes. The A85 responds fairly well to it's remote, but the DV88+ does a lousy job!
    You have to aim exactly, otherwise it won't work. Will another remote solve this issue, or is the problem with the 'eye' in the DV88+?
    Furthermore I've got another strange problem. Sometimes when I press the back button when listening to a cd, it won't work. I have to fast forward, go to the next track, fast backward or something like that first and only then it will work! Does this sound familiar to anybody?
  2. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,418
    North East Scotland
    +65
    The only suggestion I can come up with is to check the setup menu in the DV88+ - there is an option to select the type of remote you are using (I think there are four different options, including "learning remote").
    Check that your remote is the one selected in setup.
  3. szd
    szd
    Dec 4, 2000
    330
    2
    Gloucester
    +15
    I also have A85 and DV88+ and suffer from the same problem, i have to point the DV88+ remote right at the player for it to respond!!
  4. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    Over the Hill & Far Away
    +136
    my pronto works fine with the DV88+ must be the remote itself..
    Matt
  5. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,418
    North East Scotland
    +65
    My pronto is fine too....
  6. vanwel
    vanwel
    The remote setup is good. So the remote must be :thumbsdow
    Well... hopefully the problem will be fixed when i get another remote, like the pronto or so...
  7. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,418
    North East Scotland
    +65
    You know, it could be a problem with the player. Arcam are very supportive and if you e-mail their customer support, someone with technical knowledge will phone you to discuss the problem, they may have heard of it and will suggest steps to fix it.
    Try doing the same operation but using the buttons on the player, not with the remote. This may demonstrate that the problem is not exclusive to using the remote control!
    Good luck.
  8. vanwel
    vanwel
    Good thinking! I completely forgot about the fact that I had already tested that! And that doesn't work too! So it's a problem with the player :(
    Well, I have to bring it by the dealer anyway, because I can hear the cd spinning sometimes, giving a high pitched noice. Really annoying. Changing of tracks could be more quite too, but that has always been loud. However, that's not so big a problem..
