Remotely switching off a PC?
Discussion in 'Desktop & Laptop Computers Forum' started by nathan_silly, Oct 12, 2003.
  1. nathan_silly
    nathan_silly
    Is there a way of switching off another PC on my LAN remotely?- say I'm on my laptop, and I have a desktop at the end of the house (I want to switch the desktop off)
    Is this possible?
    Ta
  2. sweetmate
    sweetmate
    Aug 29, 2001
    706
    London
    +51
    If they are both Windows XP, then you can use Remote desktop to connect to and control the other machine. If not you will have to setup a similar program (something like dameware or terminal services) for both machines.
  3. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    You can use the AMD magic packet software to turn your PC and and Off over the network.
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Radmin gives you the full functionality of the remote computers desktop.
    You can actually work on the remote machine pretty mcuh as if you were sitting at it.
    I use it on a cheap little laptop with a wireless connection. I've effectively got a remote wireless terminal for all the PCs in my house.
  5. VintageMark
    VintageMark
    Apr 27, 2001
    160
    16
    Bristol
    Also depends on which OS you are using...
    If you have Windows XP on both machines... the easiest thing to do is select Start/Run... then type 'shutdown -i'.
    A utility will open which will let you select remote machines and then either shut them down or reboot them.
    If you are familiar with command line tools, you could just type 'shutdown -s -m \\computername'.
    Hope that helps.
    Mark.
  6. nathan_silly
    nathan_silly
    Thanks for the info. Since I've disabled remote on both PC's (for security reasons) does it mean I'll have to re-enable them?
  7. VintageMark
    VintageMark
    Apr 27, 2001
    160
    16
    Bristol
    If you want to use Windows XP Remote Admin... yes you will have to reenable it on at least the machine you want to shutdown remotely.
    To use command line 'shutdown' tool does NOT require RA to be enabled...
    Although I have just realised that both machines will have to be using common administrator usernames and passwords for the shutdown command to work.
    Mark.
