Remote
Discussion in 'Projectors, Screens & Video Processors' started by mintminty59, Feb 14, 2005.
  1. mintminty59
    mintminty59
    Jan 19, 2005
    55
    Does anyone know if its possible to get a seleco 350 or 390 into service mode without the use of a remote control (by a key sequence on back of unit) I am hoping to save myself £45. Or does anyone know if a universal remote control will do the same job. Any help on this would be much appreciated
    Thanks in advance
    David
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    Yes. Hold down the three-dots button 'ooo' until the onscreen display shows:
    MEMO NOR DATA
    INSTALL
    Then highlight INSTALL, then press EXIT seven times to get into install menu.
    You can do most things the cream user remote except switch the tubes on/off or global resets.
    Regards
  3. mintminty59
    mintminty59
    Jan 19, 2005
    55
    thanks for responce chris , but i dont have a remote at all and there ist a ooo button on back of unit. Can u program a one4all remote or something
  4. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    you'll definately need a remote. Check out ebay, I saw a 390 remote on there a couple of weeks ago, or get in touch with Owl and buy a replacement - approx £40, from memory.
    Regards
    Chris
