Remote Woes
Discussion in 'Home Cinema Control & Remote Controls' started by Gillykid, Oct 8, 2004.
  1. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    With my HTPC / Projector / Sounds System set up I now have 8 remote controls to juggle and now fancy an all-in-one to replace them all.
    I really fancy the Marantz SC5400 but, and this is the problem with all the remotes I have found so far, it cannot learn RF signals. In fact I dont even know if this can be done.
    Does anyone know of a remote control that can control both my IR devices (e.g. sound system) and RF devices (e.g. Home Theatre PC)?
    G
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    there are no learning RF remotes however have you considered a PDA remote? or web tablet that will be able to communicate with PC.
  3. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    Interesting.....
    Never thought of that - would it be capable of sending IR too?
    Right - i'm off to find a decent PDA! :)
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    have a search a few people have been using an Ipaq as a remote and messiah recently was selling a web pad that did all this had links to software etc have a search mate
  5. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    Ok,
    I have spent the last hour or so reading the pros and cons of using an Axim X3 to control my setup and its looking good.
    However, a lot of people haven given up and returned to dedicated remotes, is anyone out there still using there Axim / iPaq? If so, how is it going and is it worth it?
