D
Deleted member 598831
Hi there folks. I am using a bk xxls400 but it is positioned so that it is quite tricky to get to the controls. When using the high level out of my AS-500 I can only adjust the amount of bass by tghe bass control on the amp which I think is about 50hz. Sometimes, depending on source material, time of night etc I would just like to knock it back slightly, or boost
Can someone let me know if the following would be ok as an inline adjuster?
BT934 - B-TECH - LOUDSPEAKER VOLUME CONTROL | CPC
Thank you!
Steve
Thank you!
Steve
