Remote Server Turn On
Discussion in 'Desktop & Laptop Computers Forum' started by rhinoman, May 12, 2003.
  1. rhinoman
    rhinoman
    Oct 31, 2000
    2,603
    71
    Herne Bay, Kent
    +33
    I have just relocated my server PC running W2Kserver to the understairs cupboard. To control it I use the Remote Desktop Client thats is built into XP pro which is on all of my other machines.
    Using the rmeote control I can configure everything I need and shut the system down. Any ideas to how I can remotely turn it on?
    I guess I need a wake-on-lan network card connected to the appropriate MB header but I'm sure I remember reading something about having to run a script to make it work:confused:
  2. originalbadboy
    originalbadboy
    Mar 27, 2003
    238
    +3
    Do a search on the Internet for 'Magic Packet' , you should find some software to do this, and be able to trigger it via remote control ...
    The easy way to tell if a network card will work with Wake-On Lan .. is if you have your PC plugged in , but not turned on , and there is a light on the network card .... then it should work .. most network cards , and onboard lan ports made in the last few years have wake on ability ....
  3. mephistopheles
    mephistopheles
    Wake on LAN shouldn't be too much of a problem, but if you mean you want to boot it remotely, you're looking at a LOT of money for the appropriate hardware.
  4. Jeff
    Jeff
    Jul 13, 2000
    5,501
    Basingstoke
    +263
    You could use something like an airboard to trigger the power on (space bar) and use an IR repeater.
  5. rhinoman
    rhinoman
    Oct 31, 2000
    2,603
    71
    Herne Bay, Kent
    +33
    The magic packet seems to be a poissibility but I've got a lot more reading to do before I understand it.
    I do mean that I'd like it to boot from cold.
    Unfortunatly the IR wake from keyboard which I use with my HTPC wont work in this case as the machine is a long way from my study and doesn't have a keyboard,mouse or monitor attached.
    I can shut down with the Terminal Services software and I have the bios set to auto boot after a power cut but it would be nice to be able to remotely turn it back on without having to go downstairs to the cupboard.:)
  6. originalbadboy
    originalbadboy
    Mar 27, 2003
    238
    +3
    Im sorry .. buts thats just not true ... any PC with a WOL capable network card (any 20quid card should do), will be able to remote power on a PC with the right software ... its just a matter of finding the right software.
    For Example :
    http://users.pandora.be/jbosman/pwroff30.zip
    Is a a free piece of software that should do the job ... FREE being the apporproaite word ...
  7. mephistopheles
    mephistopheles
    I think you need to think that through again originalbadboy.
    If you can tell me how a piece of software can access and remotely turn on another computer's power supply WHEN THAT COMPUTER IS SWITCHED OFF, with nothing more than an unpowered WOL network card, I'll be more than a little surprised.
    The piece of software you recommended looks very interesting, but it doesn't provide anything other than shutdown/reboot and other live access actions for the reason I've hinted at above.
    To be able to remote cold boot via LAN you have to install special hardware and, for obvious reasons, it's EXTREMELY expensive.
  8. loonatic
    loonatic
    Jan 4, 2003
    1,905
    41
    Springwell Village, Gateshead
    +16
    Why switch it off ?
    I leave mine running 24-7...also under the stairs...and have done so for over 6 months now with out powering down.
    Also, check out this thread over at Kustom PC's...a guy there has an RF remote thingy which should do the trick - he sells them also.
    http://www.kustompcs.co.uk/forums/showthread.php?s=&threadid=2231
    Cheers, Lee
  9. originalbadboy
    originalbadboy
    Mar 27, 2003
    238
    +3
    As a computer engineer ... I know what I am talking about , thank you ...
    It really depends on what you mean by 'switched off'. If you mean off , and the power actually off at the wall as well, then yes , obviously that will require extra hardware, but the idea of a WOL network card, is that it draws a very small current from the PC, so that if , the 'magic packet' is sent to it , it turns on the PC.
    The same principle allows you to turn on a PC via a keyboard , or for example a modem ... The PC may be off, but as long as it is plugged into the wall and the wall socket is actually on , then you can cold boot a PC in a variety of ways ....
    You do not, I REPEAT, YOU DO NOT have to install 'special hardware' to cold boot a PC (which has power going to it) at all ...
  10. rhinoman
    rhinoman
    Oct 31, 2000
    2,603
    71
    Herne Bay, Kent
    +33
    Thanks for confirming that, have you any reccomendations to a particular magic packet product to use?
  11. originalbadboy
    originalbadboy
    Mar 27, 2003
    238
    +3
    Try the link I posted ... otherwise , just do a search
  12. mephistopheles
    mephistopheles
    I stand corrected! You're absolutely right; it works! Wonderful piece of software, originalbadboy, and just what I need, too, for my own upcoming network system at home.
    I had thought the only way to cold remote boot a workstation/PC via LAN from a server was with the kind of hardware used for OS (network distribution) installations from remote server..............
    Me and my big mouth! :eek:
    PS I am also a computer engineer, so it clearly doesn't necessarily mean you know what you're talking about when you are one..............does it? (Though, of course, I've never been wrong before LOL)
  13. rhinoman
    rhinoman
    Oct 31, 2000
    2,603
    71
    Herne Bay, Kent
    +33
    Thanks, that programs really simple and works a treat:)
  14. Ken
    Ken
    Dec 15, 2000
    367
    Stoke-on-Trent
    +12
    originalbadboy, that is a brilliant piece of software, thank you for providing the link.
    Ken
  15. originalbadboy
    originalbadboy
    Mar 27, 2003
    238
    +3
