Remote query for sr 6200
Discussion in 'Home Cinema Control & Remote Controls' started by Freddie, May 21, 2003.
  1. Freddie
    Freddie
    I am in need of a remote for a Marantz sr6200. Either to buy or to borrow and teach to a learning remote, if anyone can help I'd much appreciate it.
    Thanks, Fred
    The remote model no. is rc6200sr.
  2. cbemoore
    cbemoore
    May 16, 2002
    1,295
    38
    Esher
    +16
    I've got one. Where in the country are you?
    I'd be reluctant to post it out, but if you want to drop round to my place to program your all-in-one, that would be no problem.
    Let me know
    Chris
  3. stevelup
    stevelup
    Aug 13, 2002
    6,532
    Swindon
    +1,097
    Which learning remote do you have? The Marantz amps use standard RC-5 commands, and there is an excel spreadsheet on the Marantz website which lists all the codes.
    If you have a programmable remote that can be told discrete RC5 (Pronto and some others), you may be able to program it without needing an original remote.
    Steve
