Remote packed in
Discussion in 'LCD & LED LCD TVs Forum' started by woldsweather, Feb 20, 2014.
Tags:
  1. woldsweather
    woldsweather
    Jun 21, 2008
    I have an Aldo logix t32wlu55fhid TV and the remote has stopped working. I can't find any controls on the TV - will there be controls or don't they put them on the TYV anymore? Not sure how to get a replacement remote.
  2. noiseboy72
    noiseboy72
    Apr 24, 2011
    6,071
    +1,779
    Try a universal remote. Get a decent one - as it is more likely to get the codes.
    Before you do this however, point your remote at your camera phone and see if you can see any light flickering from the front of it when you press a button, as it may be the TV receiver that has stopped working, not the remote.
  3. JayCee
    JayCee
    Jan 20, 2004
    23,760
    Lanarkshire
    +2,570
    There will be controls on the top or side panel...they may be hidden behind the front facia...look for touchscreen-type symbols.
    As to the remote...I presume you've tried new batteries?
    A replacement can be found by Googling the model no.
