Remote operation of screen
Discussion in 'Projectors, Screens & Video Processors' started by MickB, May 28, 2004.
  1. MickB
    MickB
    May 15, 2004
    544
    28
    Hanslope,Bucks
    +43
    I've got an electric Da-Lite which uses a rocker switch for up/down motion.
    Can someone give me some suggestions for automating via a remote please?
    Many thanks
    :lease:
  2. doubledrat
    doubledrat
    Jan 24, 2004
    89
    Have you got a trigger on your projector? Then you should be able to control the screen using that. when you turn the projector on the screen will come down. When you turn it off, the screen will go back up. No need for a remote!
    if you particularly want a remote, I believe they can be bought for about £100. I think drh do one
  3. MickB
    MickB
    May 15, 2004
    544
    28
    Hanslope,Bucks
    +43
    there's a trigger on both the proj, and a 12v trigger on my processor, just not sure how to wire up to control this?
    thanks
  4. doubledrat
    doubledrat
    Jan 24, 2004
    89
    Well, I have to confess that this is a case of a "the blind leading the blind", but what I believe you need is a 12 or 24v latching switch. how you wire it up will depend on the signal you are getting from your trigger. You will need to stick a volt meter on your trigger out to see what Voltage it is giving.
    I am going through it for the first time myself at the moment. I might be able to give you more help as I learn what to do!
    I think the basic concept is, and that without a trigger Voltage it will be the same as pressing the Up Button, but with Trigger Voltage you simulate pressing the down button
  5. KW1816
    KW1816
    Jun 14, 2002
    836
    Surrey
    +14
    Or you could get one of theseX10 IR , download the X10 codes for your pronto and then replace the rocker switch with one of these Shutter control .
    The beauty is that you can then add lamp modules etc. and end up with lighting control as well as the screen.
    I've setup my Pronto so that it has a 'Start Film' button with a macro that lowers the screen, switches the main lights off, powers the DVD on etc. :D
    Kevin.
  6. doubledrat
    doubledrat
    Jan 24, 2004
    89
    ok, what we need is a 2 pole relay. where when unpowered it is switched to the A (screen up) position and when powered (from the trigger) goes to the B (screen down) position. it will need to be rated according the the power draw of your screen (mine is no more than 3 amps).
    when I find the right one, I'll let you know the maplin product code.
  7. doubledrat
    doubledrat
    Jan 24, 2004
    89
    I have a fortuna 8 channel lighting system :) very nice. i don't know if mick has a pronto, even if he does, the relay is the cheaper option, as it's only about £5 + some wire.
    I too have a 1 button macro on my pronto. impresses the hell out of people :D
  8. doubledrat
    doubledrat
    Jan 24, 2004
    89
    not fortuna, futronix (twit). my gps is the fortuna - duh!
  9. MickB
    MickB
    May 15, 2004
    544
    28
    Hanslope,Bucks
    +43
    Doubledrat,
    Muchos gracias!
    The relay sounds ideal, so if you come across the Maplins code, I'd be most grateful.
    I'm new to the forums, so this type of info is invaluable, saves a lot of frustration and trying to 'go it alone'.
    :clap:
  10. doubledrat
    doubledrat
    Jan 24, 2004
    89
    i've ordered some bits. i'll check it all works before I (potentially) give you duff info! not in a hurry are ya?
  11. MickB
    MickB
    May 15, 2004
    544
    28
    Hanslope,Bucks
    +43
    Doubledrat,
    Thanks, I look forward to your results, let me know as soon as you make any progress.
    Good luck!
  12. doubledrat
    doubledrat
    Jan 24, 2004
    89
    ok, first the disclaimer! I cannot be held responsible for you breaking anything/burning down your house by following these instructions. all I can say is that they worked for me...
    these are based on my screen drawing no more than 3amps and my PJ providing 12v with at least 30mA to activate the relay.
    you will need -
    1 diode (to prevent surge from when relay deactivates) maplin 1N4001 (6p)
    2 relay maplin FJ43W (£2.99)
    3 some "chocolate block"
    see pic :thumbsup:
  13. doubledrat
    doubledrat
    Jan 24, 2004
    89
    picture should be attached this time
  14. MickB
    MickB
    May 15, 2004
    544
    28
    Hanslope,Bucks
    +43
    Excellent!
    Just a quick query tho, does the relay need to be PCB-mounted, or can the components just be loose-wired,soldered, then use a suitable-sized box ?
    Thanks :laugh:
  15. doubledrat
    doubledrat
    Jan 24, 2004
    89
    I just loose wired them, taped up the exposed wire and put it all in a box
    my pj has a 3.5mm jack for the trigger, so I put 2x 3.5mm jacks on a bit of wire and then wired a 3.5mm plug to the "circuit". this allows me to easily disconnect the pj trigger wire (at either end).
    I used choc bloc for all the connections to the screen for ease of connection/disconnection.
    hope it works for you - it's so cool to have the screen go up and down automatically :)
    I presume your screen has limit switches? i.e. if you keep the up button pressed it stops at the top anyway?
  16. MickB
    MickB
    May 15, 2004
    544
    28
    Hanslope,Bucks
    +43
    Dobledrat,
    Thanks for all your help, its new territory for me, but I did some v. basic electronics years ago.
    Yes, the screen has auto stop at both ends, so its just a case of wiring the new circuit into the existing rocker box.
    This will also give me manual override on the rocker, just in case.
    Thanks again!
    :clap:
  17. MarkHudds
    MarkHudds
    Jun 12, 2002
    550
    +4
    MickB/Doubledrat - just wondering if you can measure your voltage at the relay coil for me?
    I'm having trouble with the same relay and wiring to drive a fan rather than a screen : http://www.avforums.com/forums/showthread.php?t=137442&referrerid=13666 , where my 12v trigger is not supplying enough amps and therefore drops to < 1V at the relay coil terminals.
    Thanks.
  18. doubledrat
    doubledrat
    Jan 24, 2004
    89
    can you not just get a relay that requires less ampage?
  19. MarkHudds
    MarkHudds
    Jun 12, 2002
    550
    +4
    Doubledrat - it would appear not!
    Tried two 12V relays from Maplins now (JM67X and FJ43W) and my 12v projector trigger goes down to 0.9V and 0.5V on the relay (no way enough to trigger the coil).
    Anyone know of a suitable relay with a really small coil resistance?
  20. doubledrat
    doubledrat
    Jan 24, 2004
    89
    hmmm. your trigger must be feeble! I think I worked out that relay I used only needed 35mA or something paltry like that!
  21. MarkHudds
    MarkHudds
    Jun 12, 2002
    550
    +4
    Yep, feeble is right ... worked out on the other thread to be 0.0024A
    I'm looking into a transistor now to amplify it!
    Anyone else had problems with Sony projector's 12v triggers? (VPL-VW**HT & HS10/HS20etc) ???
  22. Kramer
    Kramer
    I use my Denon's 12v trigger out without problem but I did finally manage to get a relay with a very low coil current requirement. Got it from work so of no use to you I'm afraid.
    My HS10 doesn't have a 12v trigger output & I imagine the HS20 the same.
    I did but a kit ages ago to allow triggering directly from the PJ but never got around to assembling it. Some day...... :D
  23. stevelup
    stevelup
    Aug 13, 2002
    6,664
    Swindon
    +1,180
    Owl do an electronic relay box. It is optically isolated and draws an absolutely tiny current from the trigger output.
    It also uses zero volt switching so you don't get any cracks or pops on your sound system when the screen is activated.
    Regards,
    Steve
  24. Kramer
    Kramer
    At somewhere over £100 IIRC :eek:
  25. paublo
    paublo
    Sep 2, 2001
    172
    South Lanarkshire
    Hi Chaps,
    good thread..
    Can anyone give me a new part number for a diode from maplin. The relay code is still valid - Min 12V 6A Relay {FJ43W} at 2.99. But the diode is discontinued..
    Paul.
  26. stevelup
    stevelup
    Aug 13, 2002
    6,664
    Swindon
    +1,180
    QL75S should do it.
    What are you driving it from though? Many 12V outputs are unable to directly drive relays.
    Steve
  27. paublo
    paublo
    Sep 2, 2001
    172
    South Lanarkshire
    Hi stevelup
    I am looking to use the 12v trigger from the Panasonic AE700 LCD projector with a DRH Slimline 16:9 screen.
    How would I tell if this will drive the relay successfully?
    Anyone else using the trigger output from the Panny?
    Paul.
  28. stevelup
    stevelup
    Aug 13, 2002
    6,664
    Swindon
    +1,180
    You've no chance I'm afraid. The Panasonic 12V output has a source impedence of 1K. You would need a relay that draws just 1.2mA. The one you have selected draws 50mA.
    You will need a transistor buffer between that and your relay. You will need a small 12V PSU too.
    I've attached a schematic for you. I'd recommend changing R1 to 10K.
    Steve
  29. paublo
    paublo
    Sep 2, 2001
    172
    South Lanarkshire
    Hi Steve,
    I will need to study the diagram and pick up some basic electronics. To be honest I dont even understand the different symbols on the schematic, but I'm sure I can find a key somewhere to explain the parts.
    Also changing the R1 to 10k? is that a resistor reference... sorry if I sound lame here.. Happy with the software side, not done any of the hardware side.. :oops:
    Any chance you could give me a maplin shopping list... :blush: or is this too much for a newbee hardware project..
    thanks again
    Paul.
  30. stevelup
    stevelup
    Aug 13, 2002
    6,664
    Swindon
    +1,180
    Disclaimer.
    If you kill yourself or blow up your projector / screen, it's not my fault!
    Here you go:-
    1 x BC548B (Maplin QB73Q)
    2 x 1N4001 (Maplin QL73Q)
    1 x 10k Resistor (Maplin M10K)
    1 x 12V DC PSU (Maplin MG81C)
    You need to be careful about the choice of relay.
    The screen is a highly inductive load and may cause contact arcing. If you use a small cheap relay and the contacts weld together it is conceivable that you could be applying both the up and down voltage to your screen simultaneously. I don't know what would happen but it is unlikely to be good...
    Therefore, I'd recommend a big power relay:-
    1 x JG58N 12V Power Relay and
    1 x JG54J Socket for above
    finally a box to stick it all in:-
    1 x N70BQ
    You can solder the bits directly to the relay base.
    I've attached a diagram showing the transistor pins.
    The diodes must also be connected the right way round. The flat line on the diagram corresponds with the stripe around the body of the diode.
    Good luck!
