Remote Light Dimmers
Discussion in 'Home Cinema Buying & Building' started by DpM, Oct 2, 2003.
  1. DpM
    DpM
    Jul 15, 2003
    4,258
    High Wycombe, UK
    +795
    I saw a 1 gang touch/remote light dimmer switch in my local B&Q the other day, I would realy like to get the same thing but need a 2 gang version. The 1 gang in B&Q was £22.99 so im guesing that a " gang is gonna be around £40 - £45. Anyone know of a place on the net where I can get one?
    DpM
    Sorry peeps just realised that I have put this in the wrong place, could someone please move it. Cheers.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,752
    Somewhere in South Yorkshire
    +4,906
  3. DpM
    DpM
    Jul 15, 2003
    4,258
    High Wycombe, UK
    +795
    Thanks for the quick reply Nigel, but the link is broken.
    Not to worry, just sorted it.
  4. DpM
    DpM
    Jul 15, 2003
    4,258
    High Wycombe, UK
    +795
    Neil, Im quite new to this sort of thing. How do I know which voltage I need?
  5. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,697
    Norwich
    +606
    Have a look at the dimmers on letsautomate as they have all sorts at some really good prices.
  6. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +216
    The wattage rating of the dimmer is related to the wattage of the bulbs you will be dimming.
    If you have a 300W dimmer, you can dim as many lights as you want providing that he wattage of all the bulbs isn't over 300.
    Voltage will depend on the lights you have. If you have mains voltage halogen or 'normal' bulbs, you'll need a dimmer suitable for that.
    If you have low voltage halogens, you'll need a dimmer suitable for it, as well making sure the transformer for your low voltage lights is dimmable.
  7. nealgs
    nealgs
  8. Mickey Mouse
    Mickey Mouse
    Oct 1, 2002
    23
    Buckinghamshire
    Hi there
    Yes, the one's from tlc direct are great - I have a two gang and a one gang in my lounge and they are so easy to program. The only downside to them is that if the power is cut you have to re-program them each time!
    Apart from that they are very highly recommended.
    Mike
  9. DpM
    DpM
    Jul 15, 2003
    4,258
    High Wycombe, UK
    +795
    TLC Direct look like the best bet, thanks for all your help peeps.
