Remote hack for Initial IDM-1210 Portable
Gavin_Hall
Guys,
Here is a remote hack for an Initial IDM-1210 portable DVD player, this hack was originally posted on another forum for a Mintek 1020 portable player, but because Initial/Mintek/Shansonic are all the same players really, it also works with the Initial 1210 :thumbsup: :-
step 1: turn on the power
step 2: enter into the set up menu using the remote
step 3: go into preferences menu
step 4: enter in the code 255135
step 5: quickly press the left arrow then the down arrow
step 6: a region code banner will appear, enter in the number zero
step 7: press set up again and your all done.
Update: 8/6/2005 You also need to ensure you have a DVD inside the player before you start the above!
Here is also a list of codes for other Initial players, simply replace the code mentioned above with the code you need! It may help somebody :cool:
CODE KEYS by unit:
IDM 830
212425
251131
IDM 7058
255451
IDM new 1731 04' model
251535
IDM 1731 03' model
251131
245515
251535
233212
255251
225435
IDM 9520
245512
233212
IDM 10 Car Change
211554
IDM 1810A
212425
251131
IDM 9530
245512
222443
IDM DVD 5820
245545
233112
C
cobra4155
I tried the region free hack for the IDM 1210 many many times and still can't get it to work. After following your instructions, I press the left arrow and then down arrow quickly but always get transferred to the next menu screen. I never get the region change banner. Please help. Thanks.
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
