Remote for old old TV
Discussion in 'Home Cinema Control & Remote Controls' started by mobily, Jan 13, 2004.
  1. mobily
    mobily
    Dec 30, 2003
    504
    Plymouth
    +3
    Hello all,
    I am moving house soon and will be buying a new 28 inch tv for my front room. So my old 15" portable will now be used in the bedroom. However I have lost the remote for it! :confused:
    So, I was just wondering is there a remote out there that would be suitable for an old old Ferguson portable television?
    I had a look on ebay and they seem to cost about 5 pounds. But I don't want to get one and then find it doesn't work.
    Cheers,
    James :)
  2. mxs
    mxs
    Nov 28, 2003
    236
    Lowestoft
    +9
    Get one from Argos, you can take it back if it does not work, they come with a list of codes for TV's.
  3. The Robman
    The Robman
    Generally One For All brand remotes are good for this sort of thing. I just looked in the manual for the URC-7541 for example and it has 12 TV codes listed for Ferguson.
