remote for nw-hd1
Discussion in 'Headphones, Earphones & Portable Music' started by Stahlhart!, Jan 13, 2005.
  1. Stahlhart!
    Stahlhart!
    Hey!
    I do have my nw-hd1 for three days now and I love it. The only thing that's a little bit annoying is that there's no remote comin with the player. I do have the RM-MC33EL and it works. Just the display doesn't show anything!
    I found some pics of the player with a remote that works, does anybody know which one this could be?
    http://www.quentis.com/shoppics/sonyipodkiller.jpg
    THX
  2. Kano
    Kano
    It looks like the RM-MC11EL remote which im using with the NW-HD3. This remote came with a MD player I purchased about a year ago.
    The RM-MC40ELK has a three line display. Not yet sold in the U.K but you can find it on EBAY.
  3. IanW
    IanW
    Feb 28, 2001
    1,572
    Wiltshire
    +119
    Guys,
    Search this forum a couple of pages ago, I asked the exactly same question and someone showed me the perfect remote.
    Ian.
  4. SteveG
    SteveG
    Jan 14, 2003
    1,024
    London, UK
    +87
    The remote in the first post is the RM-MC35ELK.
  5. Stahlhart!
    Stahlhart!
    the RM-MC35ELK? Does it work with the nw-hd1? My 33EL looks the same...
  6. SteveG
    SteveG
    Jan 14, 2003
    1,024
    London, UK
    +87
    Yes it does work with it. The NW-HD1 came boxed with the RM-MC35ELK remote in Japan. The RM-MC40ELK has a 3-line display and a jog wheel so it's much easier to navigate around with.
  7. Stahlhart!
    Stahlhart!
    THX alot SteveG! I think i will prefer the MC35, cause I came along pretty good with the 33. Does one you have a clue where to get these remote?
  8. SteveG
    SteveG
    Jan 14, 2003
    1,024
    London, UK
    +87
  9. Stahlhart!
    Stahlhart!
    THX again!
  10. Stahlhart!
    Stahlhart!
    Hey! One more question: can you maybe try to switch the players menu language to german and tell me if the remote displays everything right (in german)? Cause I'm not sure if there are any differences between several evrsions...
  11. T-Bone
    T-Bone
    Jan 16, 2005
    1,517
    48
    +52
    I think I will check out ebay and see if I can pick up one of these as the lack of a remote is very annoying. Are sony going to release the remote over here properly?
  12. mcwilk
    mcwilk
    The characteristic about the 35elk is the "k" for "kanji", they can display japanese kanji, which are very complex and big if compared to abc. The 33el can display any character but not kanji's.
  13. namastebuzz
    namastebuzz
    Dec 8, 2004
    525
    28
    Aberdeenshire
    +30
    The RM-MC40ELK is pretty good - it controls all the HD3/HD1 functions you'll need and the big display makes navigation easier.
    Someone's selling an HD1 with an RM-MC40ELK on ebay at the moment.
  14. Stahlhart!
    Stahlhart!
    so i won't have problems with the 35elk on my hd1? very good! i prefer the slim 35elk, because i don't need a big display to know where i am at the menu, it's just that i want a remote... and the green backlight of the 35elk looks better on the hd1, if that counts.
    thx to all
  15. ymboc
    ymboc
    From the audiocubes site:
    Is this true? the lcd display is disabled for the hd1?
  16. Stahlhart!
    Stahlhart!
    no! just the 2 line feature! it still works but just with one line as the 33el does with other md-players!
  17. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,069
    London
    +374
    The 40ELK comes with an Ice White blue display and looks even better. If that counts ? It will also control most of the menu functions and allow you to set EQ from the remote. BUT by far THE biggest thing is the Jog Wheel. It simply adds another dimension to the player that you will appreciate. Nor underestimate the size of the display. You need it.
    The 35 is rather simplistic in comparison. The 33EL does NOT have Kanji and it does NOT work at with the HD1. The buttons will function but not the display. I have already tried the 11EL, 33EL, 38EL, LCD does not work.
    I use the 40ELK, it's the best and was made for the HD1/3 :thumbsup:
