Remote For HD3
Discussion in 'Headphones, Earphones & Portable Music' started by HD3, Sep 8, 2005.
  1. HD3
    HD3
    I'm looking for a easy and quick to use remote for my HD3
    I know this type of thread has been put up before but the reason i ask almost again is i've heard before that some are far more easy to use than others. :eek:
    The Sony RM-MC40ELK for example i heard you can scroll through albums quickly. Problem with this remote is its seems very expensive everywhere. I don't understand why we have to pay so much for a cheap bit of plastic with cheap buttons inside.
    I've also seen the RM-MC35ELK which seems to generally be much cheaper than the MC40 but i've heard somewhere (not sure where) that they take a while to navigate through albums on the NW-HD range. Any body own this remote? what do you think about it?
    Any help would be very much appreciated,
    Thank you
  2. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,552
    England, UK.
    +553
  3. simmo2741
    simmo2741
    Does anyone have any info if the RM-MC60 or RM-MC33EL work with the HD5? It looks like the RM-MC60 doesnt have a display is that correct?
  4. HD3
    HD3
    Thanks for that, I've already had a look there and it doesn't really tell me much that i need to know, although it does review the RM-MC40ELK well it doesn't really have anything on other remotes.
