remote extender with wall plate
Discussion in 'Smart Home, Climate Control & Security Forum' started by boozydoo, Sep 30, 2003.
  1. boozydoo
    boozydoo
    Aug 10, 2001
    49
    Hi all,
    I recently stumbled across a remote extender which operates via a single gang wall plate (which is glass) wired to the main box which has the various emitters attached. Now for the life of i can't find it! I seem to remember it being quite expensive, but it is a very neat solution and i'm going to be replastering so it's the best bet.
    If anyone knows what the hell i'm talking about it would be much appreciated!
    Jon
  2. aarons
    aarons
    think your talking about the qed emmiter system i have one of these controlling main room and kitchen
  3. boozydoo
    boozydoo
    Aug 10, 2001
    49
    That's the baby, many thanks indeed!
    Do you recommend it?
  4. The Robman
    The Robman
  5. aarons
    aarons
    totally recommend.iam using it to control components in cabinet around £140 for the kit including emmiters and controller just need telephone wire to hook up.extra controllers can be added to control from other rooms
