Quantcast
Remote Extender 433mhz
Techno
I'm putting my AV equiment in a different room to my screen so I need a remote extender, the reciever of which will hopefully sit under a chair in the lounge where the screen is.
It will mainly be used to control SKY and the DVD player.
I fancied these from letsautomate.
My first question is are they right for the job. The second is that I notice that they operate in 433mhz which is the same as my wireless alarm system. Do you think this may cause a problem.
Thanks in advance.
