Remote Desktop Problem
Discussion in 'Desktop & Laptop Computers Forum' started by Molly, Feb 3, 2004.
  1. Molly
    Molly
    Jun 15, 2001
    212
    Lincolnshire
    My set up consists of a Belkin wireless router plugged directly to my NTL cable modem feeding a HTPC via ethernet cable and a laptop via a wirless card.
    I can transfer files between the two PC's but would like a remote desk top using the laptop. I've tried Windows XP remote and PCanywhere but I cannot get the software to recognise the computer I'm trying to control remotely.
    Is it software or the router setting?
    Any suggestions
  2. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Could be an account issue, to use RDP you need a user account on the pc that you trying to log on to exactly the same as the one that your using and they must both have the same password.
    It may be staing the obvious but I take it you have enbled "allow users to connect to this computor" on the machine your trying to log on. Its in my computer/properties/remote.
    If both of these are correct it may be a firewall issue?
