Remote Crashes Media Center (Vista)
Discussion in 'Microsoft Windows' started by pjkent, Jan 18, 2008.
  1. pjkent
    pjkent
    Feb 28, 2006
    55
    Hi All,
    I've noticed that occassionally my Microsoft Remote seems to crash Media Center...
    Everything is fine, then all of a sudden I get a black strip down the right hand side of the of the screen (MCE is in full screen mode) with what looks like some of the icons ghosted in white.
    I have an Antec Fusion case with the Antec version of the Imon VFD with IR reciever, which I thought might be the cause. So I disabled the IR reciever and plugged the Microsoft one in. And it happened again.
    Any idea's what might be causing this?
    PJ
  2. spyder viewer
    spyder viewer
    Dec 18, 2007
    5,846
    2
    Kent, UK
    +1,285
    Why do you suspect your remote? Why not your display/graphics combo?
  3. pjkent
    pjkent
    Feb 28, 2006
    55
    I think it's the iMon drivers - when I start to get funnies going on, I close the iMon application and the funnies stop.
    I've seen on some forums that the Antec version of the iMon application is a bit unstable.
    So a bit of a warning to anyone lookin at the Antec Fusion v2 case - great case, but you might end up having to live without the VFD until Antec release some decent drivers.
  4. afroylnt
    afroylnt
    May 9, 2006
    157
    +8
    I have the same case. I suspect the Imon drivers may be preventing my Vista PC from re-sleeping (sleeps the first time after a re-boot ) but then won't sleep again until the next re-boot - weird and rather annoying - I am going to buy a separate IR and remove the imon/VFD software completely - waste of space in my opinion....:mad:
  5. pjkent
    pjkent
    Feb 28, 2006
    55
    Yeah, a bit annoying given what the VFD should do...
    Until I get soime time to play with the VFD drivers to find if any variant of the Antec / native iMon drivers are stable, I've reverted to the USB IR sensor that cames with the Microsoft remote control.
    Seems to work ok... but I do get the odd occasion when it won't resume from sleep.
