Remote controls
Discussion in 'Desktop & Laptop Computers Forum' started by witty_name, Jul 20, 2004.
  1. witty_name
    witty_name
    Will I be able to run both a cordless keyboard/mouse and the nebula remote control, or do I risk interference?
    Ta
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    Should be fine, it would depend on the particular mouse/keyboard but I doubt there'd be a problem - they should use different IR codes. If there was then using a radio frequency keyboard/mouse would eliminate it. You can get these from Ebuyer for £15.
    HTH
    Owain
