Remote controls - how do you know?
Discussion in 'Home Cinema Control & Remote Controls' started by PKM999, Feb 12, 2009.
  1. PKM999
    PKM999
    Feb 10, 2009
    17
    How do you know if your remote control is faulty or the receiver?
    I have dont the 'camera test' and you can see the flash - does this mean it is definitely working?
    don't want to spend money on a new remote if it still isnt going to work
    Can you help
  2. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    As well as the camera test do any of your devices have receptors that flash when the signal is received?
  3. PKM999
    PKM999
    Feb 10, 2009
    17
    The remote is a Sony one for a Home Theatre System - I don't think it will operate any other devices will it?
    It is a RM-AAU023 (for sys HT-SF1300)
    Can a remote sort of 'lock out' - if the kids had pressed something or everything!!??
    cheers
  4. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    A button can easily get jammed.
  5. PKM999
    PKM999
    Feb 10, 2009
    17
    Would the remote still flash when you press other buttons though if there was a button jammed? I know you can 'tune' those universal remotes in - can you make an original remote forget?
  6. JayCee
    JayCee
    Jan 20, 2004
    23,758
    Lanarkshire
    +2,570
    Read page 61 of your user manual carefully...you may have accidentally set the remote to the wrong command mode.
  7. PKM999
    PKM999
    Feb 10, 2009
    17
    Thanks, i'd already tried the instructions on 61.
    tried it again anyway but still nothing
