Remote controls and Ext selection
Discussion in 'General TV Discussions Forum' started by loz, Aug 8, 2001.
  1. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    The only analog channel I watch is ITV.<br />Apart from that, I am watching either Sky, DVD, or VCR, which are all connected via SCART (my Philips TV has 3)
    As such, I find it really annoying that I only have 1 ext/av button on the remote and have to cycle through all the SCARTs, and s-video to get to the one I want.
    This was the same on my previous Sony TV too.
    Given that we only have 5 analog channels why do they give us the capacity to select 99, but only 1 ext/av?
    As far as I know, getting a programmable remote doesnt help, as the command to select a specific AV input isnt there. The TV only recognises av on, and channel up and down. Correct?
    Anyone have a TV and remote that has more than one Ext/AV select button?
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,529
    Somewhere in South Yorkshire
    +6,000
    Don't know about YOUR specific Sony TV, but on my last one, it was possible to "assign" each AV input (mine had 4, I think) to a regular "channel" number. eg AV2 = "8" (or whatever). If yours can do this, the method will be in the manual. It was just a case of working through the menu and setting 8 = AV2 somewhere.
  3. Beddie
    Beddie
    Jul 19, 2000
    165
    England
    +13
    The above is correct, you can assign channel numbers to AV inputs. Makes life a lot simpler. I wish my current JVC had the same option.
  4. timparker
    timparker
    I've just bought a SONY KV24LS35. It has a wizzy "New stylish remote commander operates DVD and VCR" but does not list Mitsubishi as a make under compatible VCRs - anyone got any ideas what codes to try that might be compatible?
    thanks
    tim
