Remote Controlled Volume Control
Discussion in 'Hi-Fi Stereo Systems & Separates' started by corebreach, Dec 26, 2003.
  1. corebreach
    corebreach
    I got a Magnavox 27MS343S for Christmas, and much to my dismay the audio output volume can not be adjusted through the TV's volume control. (It is literally just an audio pass-through. Since I refuse to use the god-awful integrated speakers, I need a way to remotely control the volume of external speakers. The 3 options I have thought about:
    Wired In-line volume knob (not desirable as I'm going for wireless)
    Cheap stereo receiver OR home theater in a box (unless I go eBay this probably isn't a reality, my budget is 90 USD)
    Dedicated remote controlled volume control
    This last one is the one I want to ask you about: does such an item exist? If so, is it horrendously expensive?
  2. corebreach
    corebreach
    Nevermind all this, I found a Kawasaki AV1000 surround system (only 100 watts but I have a small room) on sale for 60 USD, and it works great.
  3. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Yes they do exist......I assume you're from the US,but you could try looking at Creek Audio's passive remote attenuator,which may well fit your bill.
    www.creekaudio.com
