Remote Controlled Spur Switch?
Discussion in 'Home Cinema Buying & Building' started by galewis1, Oct 11, 2004.
  1. galewis1
    galewis1
    Apr 11, 2004
    354
    Peterborough
    +4
    Anyone out there know where I can buy a remote controlled version of this?:-
    http://www.tlc-direct.co.uk/Main_In...e_BG_Index/Spurs_13_Amp_Switched_3/index.html
    I want to ceiling mount such a switch to provide power to my projector. It's in an out of reach location, so I want to be able to cut power to the projector via a remote control switch rather than leaving the projector in stand-by via the projector's remote control. I don't want the hassle of an in-line switch on the wall.
    Gary
  2. ivor2003uk
    ivor2003uk
    Oct 6, 2003
    27
    london , UK
  3. stevelup
    stevelup
    Aug 13, 2002
    6,558
    Swindon
    +1,110
    TLC Easy Switch
    It's not cheap though... You could do it with some X10 gear. Have a look on letsautomate.com
    Regards,
    Steve
