remote controlled screen
Discussion in 'Projectors, Screens & Video Processors' started by daguju1der, Dec 27, 2004.
  1. daguju1der
    daguju1der
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    a white projection screen or plasma screen????
  3. daguju1der
    daguju1der
    white projection screen.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    then you are in wrong forum...this is for PLASMA SCREENS
  5. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,864
    2
    167
    Birmingham, UK
    +9,608
    Moved to the screens forum.
  6. summat
    summat
    Dec 16, 2004
    90
    Preston
    Hmmm, it'd sort of work, however, every time you use any RC in the room for more than 2 seconds (e.g. volume control?) you'd activate the screen.
    Also, consider that you almost certainly want an "Up" and a "Down" - the circuit is a single channel and would have to be adapted.
    Out of interest how does the screen work at the moment?, press-and-hold one of two keys to raise / lower the screen?, I'll look around for an equivalent device to help if that's the case.
  7. summat
    summat
    Dec 16, 2004
    90
    Preston
    What you need is something similar to this:-
    http://www.quasarelectronics.com/htx_hrx.htm
    Item HTX002/HRX002TP
    (although you'd need to confirm that the relay contacts will switch the same voltage / current that the switches on the screen are rated at)
    Then, all you'd need to do is wire each of the normally-open relay contacts in parallel with the screen's switches (i.e. one relay contact across the "up" switch, and one across the "down" switch").
