Remote controling power
Discussion in 'Arcam Owners' Forum' started by Vodder, Oct 30, 2004.
Tags:
  1. Vodder
    Vodder
    Jan 11, 2004
    449
    London, UK
    +8
    Is there any way of controlling the power switch via remote with the A65 and CD73? I'm well impressed with both units, but it baffles me as to why I can't control the power?
    I had the CR224 remote come with both units, although it does say in the manual the power switch on the CR389 remote doesn't work with the A65
  2. Palu
    Palu
    Hi, you can't control the power of a CD player. Only yhe amps you can switch with your remote.
