remote control work through a pj screen??
Discussion in 'Projectors, Screens & Video Processors' started by jamiev, Jan 9, 2004.
  1. jamiev
    jamiev
    Jan 4, 2004
    924
    +35
    will my dvd remote work through a pj screen???
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    depends on the remote mate and where the receivers is in relation to the remote and where the screen is RF remotes like the ones Bose use will IR is dependant but unlikely to be able to transmit straight through the screen.
  3. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    I wouldn't have thought so but it will depend on how sensative the sensor is and whether it'll pick up the IR signal from reflections elswhere in the room.
    My VCR remote is a swine, I think it should have a laser sight on it to line it up with the VCR, slightly off and it's hopeless.
    Meanwhile the home cinema room lights can be controlled from upstairs if i aim it at the hall's laminate floor, no kidding.
