Remote control, through cupboard door?
Discussion in 'Home Cinema Control & Remote Controls' started by gmt steve, May 22, 2003.
  1. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    I have a VCR inside a cupboard, and would like to use the remote control with the cupboard door closed. I don't want to use a Powermid or other such product, since it's just connected to a portable in the kitchen.
    I wondered if a length of fibre optic cable about 6" long with one end positioned in front of the IR receiver and the other fed through the door joint would work.
    Does anyone have any idea or ideas?
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,036
    No idea if that will work. You can get IR receivers that you can fit to door. Thye look like spyholes you get in doors for seeing who is outside. Xantech make them. Used with a little IR amp and emitter you have a solution. Costs though....##
    Gordon
  3. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    i wouldnt hold too much hope for the fiber optic (i just did an exam on this stuff!), you are only going to be accepting an IR signal in a very small fraction of the volume into which it was initially emitted and there will also be a relatively high loss due to interface reflection..... but in theory it is good and would be ideal if you could achieve some method of getting the IR focused a bit and have some lossy coating on the fiber....... but for simplicity id prob go with gordon
    ad
  4. DJ GA
    DJ GA
    Aug 9, 2007
    327
    +7
    I have hung a 50" Samsung on a wall, but I want Sky HD box, Samsung Blu Ray, and PS3 player in a cupboard approx a metre away, with door closed.
    What is the best option to control all the equipment remotely?
    Many thanks.
  5. Jamie
    Jamie
    Jun 27, 2007
    4,676
    Harrogate
    +1,139
    Many and Plenty depending on budget or needs
    Top of the list price wise would be a Philips Pronto 9400 or 9600 with the optional extender. Not much change out of a grand but wow.
    Certain Harmony remotes can use an RF extender (985?)
    Powermids and keene IR extenders are the more cost effective solution. The powermid has 2 halves linked by RF. One receives the remotes signal, the other emits the same IR signal, they can in other rooms, even on another floor.
    The keene IR extender is a wired solution, You choose a receiver (you can even get surface mount ones the same size as a standard light switch) which is connected to a magic box with little stick on emitters or a higher powered wand you use to control your kit.
    Some links to help you get started :)
    Keene Electronics
    Keene Electronics
    Logitech HARMONY 895 RADIO FREQUENCY UNIVERSAL REMOTE CONTROL review cheap prices HARMONY 895 RADIO FREQUENCY UNIVERSAL REMOTE CONTROL Logitech best buy discount online uk shop
    Theres even a homemade version you could build if you are handy with a soldering iron
    Infra Red Remote Control Extender
  6. DJ GA
    DJ GA
    Aug 9, 2007
    327
    +7
    Hi JimBob
    Many thanks for your help, much appreciated, I am going for the Keene IRBKITS set up, this should do the job, not sure if I will need a wand for the PS3 as this is bluetooth? Will PS3 handsets work through the wall?
    Regards
    Gary
  7. Dave964
    Dave964
    Nov 14, 2007
    1,548
    Camberley
    +260
    Yes - mine do.
  8. DJ GA
    DJ GA
    Aug 9, 2007
    327
    +7
    Hi Dave
    Thanks for that, look forward to receiving the Keane IRBKITS remote. I thought that would be it, but I might get an AV amp and speakers next as the Samsung sound is not that great!
    Regards
    Gary
  9. Jamie
    Jamie
    Jun 27, 2007
    4,676
    Harrogate
    +1,139
    Yep the blutooth works from another room (both remote and controller)
    Are you using the original remotes for everything or maybe a universal remote
  10. DJ GA
    DJ GA
    Aug 9, 2007
    327
    +7
    Hi Jamie
    I am using original remotes, if I go for a universal remote which would you recommend, there are so many to choose from?
    Thanks for your help.
    Regards
    Gary
  11. clockworks
    clockworks
    Dec 7, 2005
    3,573
    West Country
    +297
    Any Harmony will do the job - they all work the same way, just more features the more you spend.
    Get a decent amp and speakers first, though.
  12. DJ GA
    DJ GA
    Aug 9, 2007
    327
    +7
    Thanks Clockworks
    Yes I have been looking at amps, recommendations would be greatfully received, around 400 mark? I have JBL monitor 1's which are about 12 years old, they still sound good, not sure how much difference, say Tannoys would be?
    Regards
    Gary
  13. clockworks
    clockworks
    Dec 7, 2005
    3,573
    West Country
    +297
    If you've got the speakers, I assume that you've already got a stereo amp? You could just connect that to the TV in the short term.
    With a budget of £400, there are a few options from Yamaha, etc. There have been several threads about this type of system over on digital spy forums in the home entertainment section.
    However, I'd look at secondhand systems. Loads of people upgrade their AV setups, so there's plenty of 5-year old amps and speaker sets at bargain prices. £200 should get you a mid-range AV amp from Denon, Marantz or Yamaha. You won't get all the trick stuff like HD audio and HDMI switching, but you will get a nice-sounding amp that retailed for £700+ when new.
  14. DJ GA
    DJ GA
    Aug 9, 2007
    327
    +7
    Thanks for your advice, second hand is a good idea, I will keep a look out on here for one. If I can save a bit that will be great! :D
    Regards
    Gary
  15. suchat
    suchat
    Dec 22, 2008
    2
  16. dooz13
    dooz13
    Oct 20, 2009
    Hi guys,
    Envious Technology have some simple IR extenders to let you use any of your existing remotes with closed cupboard doors. I use their IRControl4 to control my DVD and Amp shut in a cupboard at the back of the room.
