Remote Control Problem
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by ChrisOH, Apr 5, 2005.
  1. ChrisOH
    ChrisOH
    Apr 1, 2005
    402
    Cardiff
    +7
    I am having problems with the remote control for my Yamaha DSPE 800 processor. Started exhibiting the following symptoms earlier tonight.
    1. Volume: slight adjustment either up or down results in massive overshoot ie it just carries on of its own accord.
    2. Menues: either unresponsive or scroll on their own.
    Does anyone have an idea whether this is likely to be a problem with the handset or the processor itself?
    Thanks in advance for any advice.
    Chris
  2. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Dont mean to be rude, but have you tried changing the batteries :)
  3. ChrisOH
    ChrisOH
    Apr 1, 2005
    402
    Cardiff
    +7
    :rotfl: strangely this did occur to me.
    I was concerned that a new remote would be hard to track down and cost some laughable amount but this was not the case and I have sent off (£15) so will see how that gets on.
    Chris
  4. ChrisOH
    ChrisOH
    Apr 1, 2005
    402
    Cardiff
    +7
    twas the remote, replacement sorts things ut
  5. jonathan
    jonathan
    Feb 8, 2002
    160
    19
    Kent
    Where did you obtain your £15.00 replacement remote if you don't mind me asking. Mine doesn't respond to certain buttons without giving the handset some serious bending/twisting!
  6. ChrisOH
    ChrisOH
    Apr 1, 2005
    402
    Cardiff
    +7
  7. jonathan
    jonathan
    Feb 8, 2002
    160
    19
    Kent
    Arrived today. Great advice, thanks!
