Hello Everyone,
I'm new to the forum and looking for a bit of help or advice please.
I have an old Panasonic DMR-EH60D DVD recorder that still has some life left in it.
I'm planning to set if up in my man cave, for the sole purpose of copying a box of old VHS tapes onto its HDD, then burning them onto DVD-R discs.
So far so good.
Unfortunately when I dug the machine out of the attic, the remote control was nowhere to be found.
According to the manual the number part number for said remote control is EUR7729KH0
A trawl on the interwebs seemed to indicate that this remote is long discontinued, and an aftermarket affair may be my only option
Question 1 - Does anyone know the number of another Panasonic remote that will (more or less) work on this machine? The reason I ask is I also have a couple of newer Panasonic Blu-ray recorders that obviously have their own remote controls but when I try either of these controls on the old beasty nothing happens, not a flicker of acknowledgment in the EH60D's display window.
I don't even get the DVD 1 OR DVD 2 indication that tells me remote is transmitting on the wrong channel so this makes me think it's not picking up the commands.
Question 2 - Does anyone know if this machines O.E. remote operates on a different IR frequency to the later Panasonic machines and therefore needs its specific remote control?
Question 3 - If the later controllers (I.e.the ones from my blue ray recorders) should work on the EH60D but don't, does this definitely indicate that its likely to be the IR reciever IC7508 that will need replacing?
My initial thoughts were to get a used or aftermarket control for this specific machine, however if someone can confirm that the other remotes should operate it, I'll try and replace the IR receiver chip first.
Thank you all in advance for any advice you can offer.
So far so good.
