Remote control nightmare
Discussion in 'Home Cinema Control & Remote Controls' started by shill, Mar 20, 2003.
  1. shill
    shill
    Ay up,
    I've recently bought a cheap pacific dvd player and yamaha cinemastation surround sound kit. Both are excellent quality - the only problem is that the yamaha remote also controls the dvd player. Turn volume up - stops dvd , etc...... see what I mean . This is really p***ing me off. Can it be that they are the same frequency ?? What can I do to sort the problem ?? Any advice would be greatly appreciated.
    Ta
    ps I don't want to change the equipment either !!
  2. Flimber
    Flimber
    Sep 22, 2002
    13,679
    Yorkshire
    +4,476
    Nasty. A hammer to crack this nut would be an IR router but we're talking £100+. Ring Yamaha.
    Mike.
  3. shill
    shill
    Ta for the advice, but sounds a bit of a costly job.
    There's no way of hacking / codes ...etc ??
    I have contacted Yamaha previously but they didn't seem too interested and recomended me to contact the supplier, but as everything is in working order I don't think they could do much ??
    Any more suggestions would be appreciated !!
  4. Flimber
    Flimber
    Sep 22, 2002
    13,679
    Yorkshire
    +4,476
    You're experiencing an unstoppable force (the IR clash) but you've got a very moveable object ("cheap pacific dvd player"). Bad analogy but there's yer solution.
    Mike.
