Remote control light switch
G
Garysweb
Basically i want to be able to turn the lights in a room on or off using a remote...simple right.
I want the cheapest possible, as i am going to sepend lots of a AV system, and its only a light switch after all.
I have seen this, will it do the job? Is it the cheapest?
http://www.letsautomate.com/10163.cfm?
p.s. There are currently 2 switches to turn the light on, will the make a difference? and how big are these boxes...oh and how easy to install??
Thanks in advance
GW
richard plumb
thats the one I've got, and its fine. I use it for the lounge. Its a reasonably discrete switch/ dimmer, and it can learn any spare IR command you've got (either nick one from somone elses pronto config, or borrow a friends remote for a few minutes a learn a spare button) - I use the VCR memory command which is never used.
You can remote on/off and dim too.
I also use X10 stuff, but sometimes its unreliable, so I reserve that for the other rooms as a security thing when I'm on holiday.
MarkE19
I also use the TLC remote dimmer. Its great VFM at about £15 inc VAT & Delivery. You can also get a slave dimmer so the lights can be dimmed from either of the 2 switches.
Highly recommended!
Mark.
Flimber
Does it remember it's dimmer setting when you turn on ? Or does it go to full ?
Mike.
A
ailean
It remembers it's previous setting, usefull and annouying all at the same time. ;)
I have noticed mine gets a little warm, I know why but it can be a little disconcerting especially for guests. :)
S
silron1
I can also endorse the TLC dimmer - use any spare remote key (keys if you want more than 1 dimmer controlled separately) - go into programme mode as set out in switch leaflet - works a treat
Ron :smashin:
A
ailean
I've yet to hear any buzzing, makes the old dimmer sound like a swarm of bees in comparison. :)
I used to hate using the main lights cos of the buzz but now it great and remoted! ;)
MarkE19
Can't say I've ever heard any 'buzzing' from my dimmer either.
There again if the receivers pumping out the DVD soundtrack at reference levels I can't even hear the neighbours knocking on the walls :devil: .
Mark.
jsebright
I'm looking for a remote dimmer with a remote slave unit. - I want to put in a battery powered remote which looks like a standard light switch. I don't want a remote control - I need to know where the switch is (it's for the kiddies room).
Any suggestions?
Jon.
A
ailean
You'll probably want an RF remote rather then IR if you're going to attach it to a wall. I'm not exactly sure what you're trying to do (move the live switch out of the way of the kids and put a non-mains switch lower down where they can reach?).
simon1
Any suggestions?
Jon.
Have a look at letsautomate
Look at X10
You will need 1x LW10, 1x TM13 and 1x SS13
As part of my X10 setup, I have a SS13 either side of our bed with the buttons configured to operate 2x bedside lamps and the ceiling lamp. The TM13 also doubles up as module to switch a table lamp on/off.
jsebright
Ailean - Yes, I want a switch lower down and by the bed, as well as a switch high up by the door.
Thanks simon1. I thought of X10 a while ago then forgot about it!
Does get a bit expensive though - the options you've priced up add up to £65 + delivery. Using the SS13 does allow me to add in a few more appliances if I want to though...
windfall
Hi all
Does anyone know of any company that sells a 3 way remote dimmer?
I have a trio of switches on my faceplate and would like to control each light seperately from a pronto.
Tone
Andrew_arkless
GW - Ive got one of these (& TLC stuff) - it was slightly deeper than my switch box & I had to sink it in by about 5mm which was a pain.
I've had two of the TLC ones fail after about 3 months, appart from this they are great! - maybe I was unlucky.
HouseofMu
Is there such a thing as a replacment for a wall mains socket that can be remote controlled and is dimmable?
I'd like to plug a small standing light into the socket and to be able to control it, from a Pronto, can this be done without going to the expense of X10 kit?
thanks
neil.
A
ailean
I've not seen a dimmable socket before, could be dangerous if someone plugs the wrong thing in. :)
There are a few plug in adapters and I have seen a couple with dim control but other then the X10 stuff they all tend to be RF controlled as sockets tend to not be in line of sight for IR (so not much use for a Pronto).
simon1
thanks
neil.
The way to control a table lamp with remote would be with a plug in module. There are a few available, but FWIR, they are all operated by RF not infa red (requiring a sererate remote). So really, X10 is your only answer (with an IR7243) if you want to program the commands on your pronto.
MarkE19
I've also seen remote sockets, but never with a dimmer. I would think it unlikely to be readily available as it would only be any good for a lamp and therefore not that many would sell.
Mark.
simon1
Philips Power Control:
Plug in dimmer modules. Operated by some of the philips universal remotes which have RF built in.
Available from Dutch West and Letsautomate.
Used to use these, before I moved on to X10 (because I'd moved on to a Sony universal remote).
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
Trending threads
Latest News
Roku announces Streambar and adds Airplay to streaming devices
  • By Andy Bassett
  • Published
Amazon Prime Day confirmed as 13-14th October
  • By Andy Bassett
  • Published
Linn upgrades Majik LP12 turntable with new tonearm
  • By Andy Bassett
  • Published
VPI announces new Prime 21 turntables
  • By Andy Bassett
  • Published
Skyworth launches 8K Q71 TV
  • By Andy Bassett
  • Published
