wrench86
Established Member
I'm having issues with my remote. Randomly last night It seems to function sometimes and other times it just won't respond. So if I press menu 10 times it might work once. This is all while pointing it directly at the IR sensor. And im about 1m away
I even stood up I was about 20cm away from it. I've changed the batteries I even tried my oneforall remote that won't work either. So I don't think it's the remote? With it working sometimes and other times it won't I'm a bit confused what is causing this.
Optoma hd27 projector.
