Remote Control Funtions in MCE2005
Discussion in 'Microsoft Windows' started by a_nicholson, Aug 24, 2005.
  1. a_nicholson
    a_nicholson
    Hi All,
    Having just got myself an nice new PV300 37" I have been playing around MCE 2005, mostly because of HiDef and the fact my DVD player is not prog scan, and I must say I'm impressed.(I had been using XBMC on my XBox) The only hurdle is accessibility, so I am thinking about getting a MS remote control.
    But would like to know a couple of things first:-
    Can the buttons be reprogrammed to other funtions?
    Does is have features like right mouse button click (quick menu) as I am thinking of using Theatertek for DVD and not Media Centre.(I will use MC for audio and TV recording though).
    Also, are there any small keyboards that anyone has used they can recommend.
    Thanks for any help.
    Andrew
  2. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    No...
    Try this..
    http://www.gyration.com/go24airsuite.htm
  3. Skunkpipe
    Skunkpipe
    You can only reprogram the vol up/down and TV power keys I'm afraid.
    Keyboards - the BTC9116 is small, and good VFM (£20ish) and has built in mouse/joystick. The Gyration ultra is also good but expensive(£90).
    You could also look at the ATI all in wonder remote - an RF device that can be reprogramed to be any key you want. I beleive some ppl have reprogramed this to be a MCE remote - plus it gives you mouse control and buttons
  4. OneEleven
    OneEleven
    I can vouch for the BTC9116 - really compact and solid. Great for the money :smashin:
  5. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Theatertek is compatible with the mce remote, all functions within theatertek can be accessed using the mce remote.
  6. Spacecat
    Spacecat
    Apr 1, 2001
    3,345
    London
    +979
    try Harmony 680 Esp designed for MCE 2005 and all your equipment
    works great by Logitech
  7. TheCrow
    TheCrow
    Jul 16, 2004
    659
    2
    28
    London
    +76
    I use the BTC 9019 keyboard and Harmony 655 Remote.
    The 655 doesn't come with a USB IR receiver so I have a MCE remote as well.
    The cool thing I like about the Harmony remotes is the single button activities, you just hit "Watch A Movie" and it switches on my plasma, sets it to the correct input, switches on my AX10 and sets that to the right input, and resumes my HTPC, then the Volume, Channel Up/Down etc controls the appropriate devices. Swapping activates switches on/off the appropriate kit and sets the correct inputs and controls the right devices. It makes it really simple for someone else to use the system even if they don't know/understand how everything works together.
    The 655 has the four coloured buttons for teletext, Sky etc.
  8. JonLeach
    JonLeach
    Sep 17, 2002
    755
    Deepest Darkest Yorkshire
    +22
    i too can vouch for it although i have never managed to ge the \ key working tried all sorts of combinations needs to be in line of site of the ir receiver though
    also have a mce remote, Processor remote............
    Jon
  9. a_nicholson
    a_nicholson
    Excellent, thanks for all of the help. I'm going to start by getting a BTC9116 and then see how it goes..
