Remote control for screen
jonrud
Hi I have a built in electric screen with a rocker switch for up & down let into the wall does anyone know of a convertion to make it remote control or anyway it can be converted.
KelvinS1965
It depends on the make. For example if it's a Da-Lite screen, then you can buy an infra red reomte kit for it for about £200. If you can find out what make it is then it might be worth posting back. :thumbsup:
AV Nik
Most external IR or RF remote KITS will operate any electric screen.
Hope this helps.
jonrud
There is no ir pickup on the screen i need to convert the up & down switch with a ir remote kit were can these be purchased?
