Question Remote control for PDP508XD
Discussion in 'Plasma TVs Forum' started by Theislandman, Dec 28, 2018.
  1. Theislandman
    Theislandman
    Dec 28, 2018
    4
    Worcester, UK
    I have been given a Pioneer PDP-508XD plasma tv.
    I have the remote that it came with, AXD1551.
    No matter what I try, I can’t get any connection between the TV and the remote.
    The remote shows it’s working (an led lights up), but I can’t get it to do anything with the TV.
    Can anybody help?
  2. JayCee
    JayCee
    Jan 20, 2004
    23,373
    Lanarkshire
    +2,516
    The Red led on a remote is simply confirmation that a button has been pushed, it is no guarantee that an IR signal is being output...to see that point the remote at a mobile phone video camera and look through the viewfinder, you should see a pulse of light when a button is pushed.
  3. Timmy C
    Timmy C
    Oct 10, 2003
    5,548
    +544
    You've probably sorted this by now but if not, I think it's a multi purpose remote. There are 4 red lights in the middle somewhere that shows what function is selected (TV, DVD etc) so if you haven't already then toggle through until the red light shows TV is selected. Hope that helps!
