remote control equipment in another room
Discussion in 'LCD & LED LCD TVs' started by craigsomers, Feb 4, 2005.
  1. craigsomers
    craigsomers
    i have now mounted my 32pf9986 on the wall, looks great thanks for all the advice.
    I Now want to move my sky box & dvd out of site into a cupboard. Is there a remote control extension that will be enable me to have a receiver visible somwhere that will then pass the signal onto my devices where ever they may be.
    :D :D :D :D
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
  3. craigsomers
    craigsomers
    I need somthing very simple just a receiver hard wired to a sender with 5M cable connecting the two. Any Ideas
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    you can buy the bits tou need cheaply from keene
  5. craigsomers
    craigsomers
    Thanks Got a MARMITEK POWERMID XL REMOTE CONTROL EXTENDER
    From Keene
