Hi there! I am new here and glad to find such a forum.
It's amazing - there is some form of a forum or discussion group for almost any type of interest you may have! It's great!
I am making a program for myself, and others. It basically allows you to control your TV using a mobile device (via infrared).
I am looking for TV codes that allow me to change the channel or volume.
I cannot seem to locate the manual for the TV at the moment. I just would like to know what these codes are. I need these codes so I can send the appropriate instruction to the TV to perform an action.
I am unsure of what TV Model the TV is but it is a toshiba and the remote control model is Toshiba CT90101, which appears to be compatible with these models of TV Sets:
28ZD26, 32ZD26, 32ZD26KIT, 32ZD26P, 32ZP18Q, 36ZP18Q, 36ZD26P, 36ZP18Q, 42PW23P, 42WH18B, 42WH18D, 43VJ13P, 50WH18 and 50WH18B
I do not mind what model I can get the codes for as long as it is for one of the models listed above.
Does anyone know where I can obtain such codes? I hope this is ok for this forum!
Thank-you
Thank-you
