Remote codes for Alpha 10 needed
Discussion in 'Hi-Fi Stereo Systems & Separates' started by timmorris, Sep 7, 2007.
Tags:
  1. timmorris
    timmorris
    Feb 9, 2006
    432
    +23
    We inherited an Alpha 10 with the house and no remote. I know that it uses RC5 device 17 but can't find the function codes. Does it respond to discrete on/off?
    Tim
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    Most Arcam amps respond to RC5 System Code 16 rather than 17.
    If you are sure it uses System code 17 it might be worth trying the following codes as they are the same as used on the current products that use System Code 16.
    Power On: 17-123
    Power Off: 17-124
  3. timmorris
    timmorris
    Feb 9, 2006
    432
    +23
    Should have mentioned - it's a tuner.
    Tim
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
